Re: crank pulley
Posted by Pete in Holland, MI on January 14, 2013 at 06:32:07 from (198.36.95.21):
In Reply to: crank pulley posted by tuckaway on January 13, 2013 at 18:33:00:
The big question is: Is it just a small piece, or is the pulley cracked elsewhere ?
Hang the pulley by itself from a wire. Strike it with the handle of a plastic screw driver, and listen.
If there is a slight solid ring to it, you're OK. If it has a definite "tuck" sound, there probably is a crack elsewhere.
Use caution using a cracked pulley.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
