Re: 450 Governor and hydraulic question
Posted by D Slater on January 14, 2013 at 13:38:10 from (184.15.8.141):
In Reply to: 450 Governor and hydraulic question posted by mike Fitz on January 14, 2013 at 12:01:40:
Thats a aftermarket Rocket power governor. Adjustments are made the same except for the one adjustment is made a little different way. If the vertical rod length needs changed the bolt is removed and the lock nut on the joint is loosened and the joint turned on the rod to change length.
Also did not say the valves will work, unless you have the IH power steering from the hydruatouch system. If so the valve on right in picture won't work.
This post was edited by D Slater at 15:02:04 01/14/13.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
