Re: 460 engine
Posted by Owen Aaland on January 15, 2013 at 00:30:50 from (216.47.35.246):
In Reply to: 460 engine posted by jlwimer on January 14, 2013 at 19:54:40:
It has to be a later model 303 combine. The earlier ones used the BD220 engine. The 315 combine also used the C221 engine.
In addition to the other engines listed in the other post there is also a C282, C291 and a C301 that use the same style block.
