Re: Farmall M Head Gasket R&R
Posted by Zachary Hoyt on January 15, 2013 at 16:16:12 from (173.84.189.46):
In Reply to: Farmall M Head Gasket R&R posted by PAvegfarmer on January 15, 2013 at 15:59:38:
Others will have more and better ideas, but I would definitely
look at the sleeves to see if there is a "ridge" at the top, which
would indicate that the sleeves are worn. I was told to torque
the head bolts in a spiral sort of pattern from the center outward
and to step the torque up, maybe in your case something like
torque all to 70, then to 90, then to 110. That is supposed to
result in better sealing or something. I have done an H and a
300 with those methods and both seemed to be fine afterward. I
used copper coat, don't remember who made it but I am sure it
is the same as the permatex stuff you mentioned.
Zach
