Re: Farmall M Head Gasket R&R
Posted by F-Dean on January 15, 2013 at 18:12:40 from (70.193.197.112):
In Reply to: Farmall M Head Gasket R&R posted by PAvegfarmer on January 15, 2013 at 15:59:38:
At 110 ft-lbs torque, you do not need a sealer. Use grease. This will allow the gasket to spread out/move as you torque it in the spiral pattern described by others. I would go in 10 ft-lb increments after 80 ft-lb.
