SA Seal Problem
Posted by Doug Kieta on January 15, 2013 at 18:13:32 from (71.54.113.177):
Does anyone have a valid cross-oover number for SA part #51-494-DA. This is the oil seal for the differential shaft on a SA. I went to our local IH dealer today who said he had two of them. However, when I got there, the seal he showed me that had this part number was significantly larger in diameter than the one that came out of my tractor. The old seal is a National #410060-SSR. I also tried our local bearing distributor and he was unable to cross the National number into a modern seal. I also tried NAPA. They were able to cross the number but the seal they came up with was also much larger in diameter than my original.
I am dead in the water until I can find this seal. Any help you guys can offer will really be appreciated.
Thanks.
