Posted by Paul from MI on January 15, 2013 at 19:16:33 from (204.106.250.243):
In Reply to: Chain points posted by KTNC on January 15, 2013 at 15:37:04:
I have used the same system for many years with no problems. Bear in mind, the heaviest of my tractors weighs about 3500#. I make a U shaped loop of 3/8 x 2 steel that fastens to each frame rail just behind the front wheels. In the rear I add a 3/8" thick plate to the drawbar with a hole in it big enough to accomodate 2 chain hooks. Normally the drawbar is designed to be the strongest attachment point on the tractor. Then I use a chain and binder at each of the 4 corners to hold it to the trailer. I paint the attachment points the same as the tractor so the appearance isn't damaged. I use the same method on my Allis B, John Deere B's, and Farmall H. email if you want photos.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
