Posted by JRSutton on January 16, 2013 at 09:19:55 from (75.130.109.233):
In Reply to: just curious posted by Tuckermac on January 16, 2013 at 04:35:42:
I agree that if it runs ok don't worry about it - but if you want to satisfy your curiosity, check it out.
but I'd also check your valve lash while you're poking around in there - good idea to do it anyways.
And if you want to check your compression without borrowing a gauge, just put a little oil in the spark plug hole of each cylinder and see if it gets any harder to turn. If it does you know your cylinders are worn. (do the valve adjustment first of course)
... and knowing that your cylinders/rings are worn... all you've got to do is ignore it if it runs well enough.
and - this is probably obvious, but I've seen people forget - be damn sure the ignition is off when you're turning the engine by the fan! It could very easily start up on you.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
