Re: Stuck Farmall F30
Posted by gene bender on January 16, 2013 at 16:54:08 from (67.55.226.151):
In Reply to: Stuck Farmall F30 posted by koehleraj on January 16, 2013 at 13:12:33:
Remove the plugs and use a lite to see the walls and if they are rusty aint any snake oil going to free it up. When you remove the plugs look at their condition if they are rusty also that probably means trouble also. You will be better off in the long run by removing the head that way you can inspect the valves also. Headgaskets arent that expensive.
