47 m cracked rear case
Posted by Brady miller on January 16, 2013 at 17:46:12 from (172.0.215.29):
Gents,
I've got a crack in the underside Of the rear case of the tractor. Can you Weld cast or can you fix it with j b weld? The tractor is leaking Rear End fluid. Has anyone experienced this problem before
