Posted by Lmack on January 16, 2013 at 18:16:37 from (24.131.58.167):
In Reply to: Super c p.t.o. fix posted by Pete Cormier on January 16, 2013 at 13:38:42:
The PTO bull shaft is located behind the belt pulley housing or the belt pulley delete plate. To investigate you remove the belt pulley housing or the delete plate then remove the bolts that hold the bull shaft in place. You do not have to remove the PTO shaft or the housing around the PTO shaft. The PTO shaft is driven by a single gear off the bull shaft. The bull shaft has a sleeve that slides over the PTO bull shaft using the PTO control lever at the rear right of the housing to engage or disengage the PTO. It is possible to assemble the shaft in such a way the control lever does not work, that is the forks are not properly aligned over the sleeve. The forks may be damaged or broken. The sleeve is the part that slides into a matching cog at the front of the transmission to engage the PTO or disengage if slid to the rear. If you disengage the PTO with the bull shaft out you are going to have a tough time getting it lined up to reassemble without removing the top cover of the rear end. I suspect that you had better plan on doing that from the start. Let us know what you find when you get in there.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
