300U TA oil seals
Posted by Bkpigs on January 16, 2013 at 19:04:04 from (24.182.229.14):
Working on Dad's 300U, supposed to be a rather easy axle seals and brake fix. But like everything it has snowballed. The TA seals are leaking. When I fixed my 300 rowcrop I split it into three pieces. Is there any way to just split it once? I am 99.9% sure this isn't possible but figured it was worth askin. Thanks!
