Re: B-450 Diesel Terrible smoking and raw diesel out of exha...
Posted by cushman on January 16, 2013 at 19:06:28 from (71.54.71.230):
In Reply to: B-450 Diesel Terrible smoking and raw diesel out of exha... posted by frazier2cyl on January 16, 2013 at 13:02:18:
I am concerned with that tight of ring end gap,especially,if you are going to turbo the engine.With a 4" bore,I would want to see .025 ring end gap to prevent seizing it up when you start making it work.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
