Re: ice on carb
Posted by Tom Fleming on January 17, 2013 at 03:48:29 from (67.20.233.75):
In Reply to: ice on carb posted by Mlkgsmer on January 17, 2013 at 03:38:59:
Is it affecting how it runs? The venturi portion of these carbs always will "ice up", even in warm weather. If the ice you are refering to is on the outside of the carb, there is no harm, in fact, it indicates your carb is "breathing" normally.
If you have internal icing, you have water in the fuel. Dry gas or similar will correct that. Plus, drain your fuel tank completely and keep the moisture out of it by keeping it relatively full (or in a heated building).
This post was edited by Tom Fleming at 03:48:48 01/17/13.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
