Re: B-450 Diesel Terrible smoking and raw diesel out of exha...
Posted by Cvrush on January 17, 2013 at 05:17:07 from (109.153.235.50):
In Reply to: B-450 Diesel Terrible smoking and raw diesel out of exha... posted by frazier2cyl on January 16, 2013 at 13:02:18:
Correct injection pressure for these injectors is 110 Atmospheres (110 x 14.5 = 1595psi)
If injectors are serviced to specifications as laid down in the service manual there should not be excess diesel in bore
Also is it possible fuel pump is over fuelling ?? specifications for injection flow rates are specified in the appropriate service manual !!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
