Re: White foam on oil breather cap
Posted by kurt on November 03, 2000 at 14:52:36 from (63.69.63.251):
In Reply to: White foam on oil breather cap posted by marvin on November 03, 2000 at 14:15:34:
sounds like your getting condensation build up, caused by the temp. change outside. change your oil just to be safe and see if there is any water in it. if not it's condensation. nothing to worry about much just change your oil a little more often than you normaly would, and if you plan on letting it sit for any long periods take your valve cover off and clean the foam up then pour a little oil over your valves. hope this helps
Post A Followup
: Re: Re: White foam on oil breather cap
