If your sw is 4 position the system did have a cut-out originaly. Get the DelcRemy # on the gen if you need to replace the cut-out. I would take it to a gen shop and they should be able to check things out. That charging system needs all componets to have a good ground clear thru the sw for it to work.Simple test with engine running ground the field and if that makes it charge the cut-out is bad if it doesent charge the gen is bad. You can use an OHM meter to check all componets for ground.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
