Re: 706 3pt hitch question
Posted by pete 23 on January 17, 2013 at 11:02:30 from (74.32.229.189):
In Reply to: 706 3pt hitch question posted by Kirk Affeldt on January 17, 2013 at 10:39:03:
You cannot turn it around as the mounting holes will not line up. Different equipment requires diffferent height of third arm so, many will work on upper hole, others require lower hole. If you don't have an operators manual with the equipment you want to use, then cautious trial and error will suffice to see if it works out with the one hole you have.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
