Re: 560 Brake seals
Posted by pete 23 on January 17, 2013 at 11:13:55 from (74.32.229.189):
In Reply to: 560 Brake seals posted by Bill in IL on January 17, 2013 at 10:19:47:
That plate just prys out and you replace seal from other side.
Seal #357037R91 0-ring #254693R1 which has been changed to case number 70923601. Parts are shown with the rear frame and driving members differential section. You will see the brake shaft bearing and that shaft can be just pulled to inspect that bearing also.
