Re: Super A antifreeze in oil
Posted by Farmall dean on January 17, 2013 at 14:40:54 from (216.228.194.178):
In Reply to: Re: Super A antifreeze in oil posted by JRSutton on January 17, 2013 at 14:20:30:
I torqued to 65 about 15 years ago because that is the Repair Manual spec, however it seems that best practice is to 8o lbs. I think I may have retorqued it (don't remember-I don't seem to remember much of anything anymore) and if I did I am sure it was to 65-70lbs. I am going to remove oil pan first because I want to eliminate bad sleeve seals as the culprit. My mechanic has device for pressureizing radiator if necessary. Can't go much above couple pounds because radiator is original.. I don't want to change head gasket and then find I have bad sleeve seals and change head gasket 2nd time. Dean
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
