Re: 706 3pt hitch question
Posted by Janicholson on January 17, 2013 at 15:22:24 from (74.60.94.18):
In Reply to: 706 3pt hitch question posted by Kirk Affeldt on January 17, 2013 at 10:39:03:
If you want to make it operational you could clean it up and take it to a welding repair shop. A good welder can make it as good as new or better. Used parts might be cheaper. Jim
