Re: Need help, Generator Cutout or voltage regulator
Posted by Bob M on January 17, 2013 at 16:44:47 from (67.240.174.32):
In Reply to: Need help, Generator Cutout or voltage regulator posted by Philip P on January 17, 2013 at 06:37:03:
Phil - You can verify whether it is a cutout by removing the cover. If there's only a single relay inside it's a C.O.; 2 relays makes it a voltage regulator.
The OEM cutout has 3 terminals: GEN (or ARM), BAT and FLD. If the tractor is equipped with lights (evidenced by the 4 position light switch), the cutout FLD terminal is NOT used.
The only time the C.O.'s FLD terminal is used when tractor has no lights. It then gets connected to the generator F terminal.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
