1086 lift question
Posted by gbs on January 17, 2013 at 20:27:56 from (108.206.48.224):
our 1086 3 point lift will leak down about 2 inches then raise back to the set position unless the draft lever is set about mid range then it works fine ,what would normally cause this condition worn control linkages or adjustment,is this a common problem, would like to know what might be causing the problem before i attempt to go through the adjustment procedures and possibly miss the problem
