Re: Delco-Remy Generator Output
Posted by John T on January 18, 2013 at 05:21:42 from (66.87.7.198):
In Reply to: Delco-Remy Generator Output posted by SadFarmall on January 18, 2013 at 04:23:41:
I dont have the specs on your genny, Bob M or Jim might?? However, Id guess 20 amps is all it may pump on a good day AT HIGH RPM
Try to dead ground the Gennys FLD post and see what happens??? If charging dont increaSE much the VR is NOT the problem nor will adjustments help. If it does increase, (may need adjusted up) insure the VR has a good ground (try a jumper to grnd)
If its a 3 brush genny, adjusting the third brush may help....Insure belt is tight........Can you use a smaller pulley on genny????
Other things may be to check brushes for length,,,,,,insure brush hold down springys are good n tight,,,,,,,,insure commutaTOR IS CLEAN and free or oil or carbon ,,,,,,,,,if third brush adjust,,,,,,,,,INSURE VR well grounded,,,,,,,,belt,,,
Unless youre gonna run hours n hours with all lights on May just live with if the above is all good
John T Live from Florida Flywheelers
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
