Re: ihc 4586 tach reading
Posted by ihman73 on January 18, 2013 at 22:24:08 from (38.104.162.142):
In Reply to: ihc 4586 tach reading posted by jim_uny on January 16, 2013 at 02:37:55:
The likely culprit is a bad electrical connection in one of the harness connecters. Start popping apart and cleaning and it will likely clear up.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
