Re: 7120 ele problem
Posted by Jim Naden on January 19, 2013 at 01:43:46 from (12.74.49.95):
In Reply to: 7120 ele problem posted by Rod k in Iowa on January 18, 2013 at 19:03:16:
Rod k in Iowa said: (quoted from post at 20:03:16 01/18/13) With the key in the on position it reads acc and hrs as it does in acc position. When the tractor starts and the key returns to the on position the tractor stops. It is not the fuel solenoid or the key switch and I have checked the grounds. Any ideas?
Replace your cab solenoid.
In some instances you get a backfeed that energizes the ACC circuit with the key in the run position.
This post was edited by Jim Naden at 02:30:26 01/19/13.
