Re: FRONT OIL SEAL
Posted by gene bender on January 19, 2013 at 08:37:26 from (67.55.226.151):
In Reply to: Re: FRONT OIL SEAL posted by Janicholson on January 18, 2013 at 15:50:54:
The housing is sheet metal also and care sould be taken looking at the cover as sometimes they do get bent thus the seal will ride crooked on the crank pulley. You cannot replace the seal in the housing to avoid the worn spot on the crank pulley. It fits in a small place and will be in the same spot as the original so replacing new seal to ride on a different spot is not possible. Most cases a speedy sleeve is needed on the crank pulley
