Re: W4 rear rim
Posted by Ol' Gimpy on January 19, 2013 at 16:08:34 from (67.252.122.95):
In Reply to: W4 rear rim posted by charlespretzer on January 19, 2013 at 11:28:02:
First-Where are you???? I have a couple of them,but you may locate one locally,since many old combines used 26" rims/tires. However,you would need to remove the riveted center,weld up the rivet holes,and take the old "Lugs" off you old rim,or weld in new ones.Using 13-26 tires?? May note several rim widths,depending on tire size.
