Re: Plow parts
Posted by Lmack on January 19, 2013 at 18:03:47 from (24.131.58.167):
In Reply to: Plow parts posted by Jim O'Connell on January 19, 2013 at 13:17:28:
I suggest you get the Super Chief replacement bottoms since the wear parts are readily available. IH did not change the bolt up pattern from the beginning to now so the new Super Chief bottoms should replace your existing bottoms with no modification needed. My dad changed ours out to Super Chiefs back in the 1960's.
