Re: Janicholson IH460 wiring
Posted by Janicholson on January 20, 2013 at 19:16:07 from (74.60.94.18):
In Reply to: Janicholson IH460 wiring posted by ldb on January 20, 2013 at 18:27:11:
The wire from the stud on the back of the ALT. (red 10ga.)goes directly to the amp meter. The amp meter is a shunt device. (it has a heavy conductor inside with a known very small resistance. This resistance has the meter connected across the terminals. Thus it passed plenty of amps) The 10ga. wire then goes to the starter motor solenoid, where it connects to the battery cable from the + battery post. From there it goes to the battery, charging it. The - battery cable is grounded, as is the alternator, thus completing the charging circuit. Jim
