Re: IH 460 hydra-touch issue
Posted by Janicholson on January 21, 2013 at 12:29:49 from (74.60.94.18):
In Reply to: IH 460 hydra-touch issue posted by Noah in IA on January 21, 2013 at 10:40:44:
Getting to the valves in the cold is tough. If inside. (-8 degrees here today) take the sheetmetal off to gain access. look to be sure the linkage is actually free (moves a little) if so remove it and put some ATF on the valve spool where it is visible.
tapping on the spool with a plastic hammer while turning on the flat, where the hole is, with a small wrench can free them up. No whacking, and no major twisting. Jim
