Re: Seals to replace packing
Posted by Nebraska Kirk on January 21, 2013 at 17:25:33 from (207.91.4.159):
In Reply to: Seals to replace packing posted by Mark Poss on January 21, 2013 at 09:32:54:
It probably is possible, but some machining will probably have to be done. You can new generic packing from McMaster Carr, either graphite or PTFE impregnated. Either one is pretty cheap. Since the sealing surface will be worn from many years of use, a modern oil seal may not seal very well. Whereas the packing is much thicker and has a better chance of sealing I would think.
