Thanks for the info., but I did check the heat riser flap and spring. They're both present and seem to be working well. The weight starts out vertical when the manifold is cold, and slowly moves to horizontal as the manifold heats up. It moves very easily and the spring always returns the weight to the vertical position when the engine is off and cold.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
