Re: FARMALL 460 Stalling Issue
Posted by RJG on January 21, 2013 at 21:00:57 from (74.46.209.110):
In Reply to: FARMALL 460 Stalling Issue posted by The tractor vet on January 21, 2013 at 19:03:05:
Is 1 5/16 the float setting? That would be the distance from the bottom of the float to the carburetor surface above it, correct??
Thanks.
Bob
