Re: penetrant
Posted by Tom Fleming on January 22, 2013 at 03:19:40 from (67.20.233.75):
In Reply to: penetrant posted by ken house on January 21, 2013 at 18:45:30:
Kroil is one of the best on the market in my humble opinion. Blaster is also fairly good. Price wise, Blaster is much cheaper than Kroil.
I tried the acetone/tranny fluid mix. It seemed to work well, but I had trouble keeping the two mixed properly. Not sure what the issue was, but it separated on me, and the acetone evaporated off.
The idea of a good penetrating oil is to have a very low surface tension. This allows it to literally penetrate the microscopic pores in the rust crystals, and "break them down" somewhat. Lubrication is also an important factor. If you look at Kroil and Blaster, they have the correct characteristics mentioned: low surface tention and lubricity. Solvents are great for penetrating microscopic pores, but they have little to no lubricity. Diesel is a good low viscosity lubricant, but has a much higher surface tension than Kroil or Blaster.
An independent study showed that the Acetone/tranny mix was one of the best penetrants. They tested penetrants for break-out torque on rusted nuts, with interesting results. They arranged a subjective test of popular penetrants, with the control being the torque required to remove the nut from an equivalent "scientifically rusted" environment:
Penetrating oil ........... Average load to break free
None ..............................516 pounds
WD-40 .......................... 238 pounds
PB Blaster .....................214 pounds
Liquid Wrench ............... 127 pounds
Kano Kroil ......................106 pounds
ATF-Acetone mix............ 53 pounds
The Acetone lowers the surface tension of the tranny fluid and "transports" it into the pores.....then evaporates.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
