Re: C113 heads
Posted by Red Dave on January 22, 2013 at 09:37:57 from (66.216.141.163):
In Reply to: C113 heads posted by Mr farmall on January 22, 2013 at 09:19:25:
You can have a machine shop check it for flatness and plane it flat if it is off.
The later headgaskets get torqued to 80ft lbs, then get retorqued after the engine is run a bit to warm it up.
Use sealant on the head gasket too.
