Do both levers move the same? Both should have four positions, all the way back for up, neutral, one click forward for down, and a second click forward for float.
The stop bolt tractor vet is talking about is on the bracket that holds the lever. If it is holding the lever from moving that is why you don't get power down. Remove the stop bolt and see if that makes a difference.
Does the tractor make grunting/squealing noises when you aren't getting power to the cylinder? If so it's probably the coupling. It is trying to force pressure but can't because the coupling is bad.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
