Re: Farmall H lift-all drive shaft loose
Posted by Janicholson on January 22, 2013 at 17:27:37 from (74.60.94.18):
In Reply to: Farmall H lift-all drive shaft loose posted by John in ct on January 22, 2013 at 14:44:38:
Aligning the slots and bars with a hose clamp then drilling through the cotter key holes to a little bigger size and using a close fitting bolt with locktite on the nut would improve it a lot. Jim
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
