Re: Farmall H lift-all drive shaft loose
Posted by Owen Aaland on January 23, 2013 at 01:46:30 from (216.47.34.168):
In Reply to: Farmall H lift-all drive shaft loose posted by John in ct on January 22, 2013 at 14:44:38:
It sounds like there was a problem with the couple being too tight before you took it apart for repairs. The coupler should be loose when properly installed. About the only problem I've ever seen with them is if the cotter pins are left too loose they can move and cause wear. After about twenty years like that they can wear enough to fall out.
