Posted by old on January 23, 2013 at 09:00:01 from (209.86.226.32):
In Reply to: H carb adjustment posted by Tuckermac on January 23, 2013 at 05:54:05:
Could be the govanor going bad or it could well be the carb out if adjustment. If the main jet is set to lean and or if clogged up yes it will surge up and down. I would start by pulling the main jet adjustment parts out the needle and the part the needle sits in. Turn on the gas and make sure you have a good flow of gas out of it. Also take a small wire etc and poke into the main jet to make sure it is in fact open. I use a torch tip cleaner tool for that. Then put the parts back on and start at say 4 turns out from bottom and adjust it from there
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
