Re: International 100 how can this be?
Posted by CNKS on January 23, 2013 at 17:51:42 from (216.144.104.128):
In Reply to: International 100 how can this be? posted by Nathon on January 23, 2013 at 09:39:57:
559 is a 1954 model. See if you can find a casting code on the clutch housing, The letter should be A for 54, meaning the casting was replaced. The serial tag could also have been replaced. The tag could also be a 55 if you can find another number after the 9. To be a 56 it has to have 1 as the first number and another number following the 9. If the 559 is very clear, then you have a different casting.
