The resistor is to prevent substantial current from flowing into the alternator from the ignition in the case that the alternator's internal regulator shorts out. It is a bit redundant in that the resistor alone will work to allow excitation. I have not seen any (nor heard of any) shorted to ground regulators that cause the issue above, so I don't recommend te use of both. But I have no issue with a marker lamp, diode, or resistor at or above 10 ohms being used to limit back feeding the ignition. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
