Re: Farmall Super A Camshaft removal
Posted by Machine249 on January 23, 2013 at 19:01:31 from (76.100.246.141):
In Reply to: Farmall Super A Camshaft removal posted by adamih on January 23, 2013 at 16:28:50:
As stated before, remove lifters and oil pump, then try to pull out from the gear end. If you try to pry on the gear you will break the gear and/or camshaft (ask me how I know). If push comes to shove, on the back side of the cam is a plug, like a freeze plug, it can be removed and the cam can be tapped out from the rear. I had a C113, that had sat for a loooong time and everything was seized. Be patient and good luck with it.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
