Re: Need info on 450 hydraulic regulator/safety valve block
Posted by Centex Farmall on January 24, 2013 at 20:17:20 from (166.137.116.34):
In Reply to: Re: Need info on 450 hydraulic regulator/safety valve block posted by Hugh McKinney on January 24, 2013 at 20:02:53:
A photo would work, showing the parts as if they are in an exploded diagram. I'm mainly interested in the main hydraulic pressure regulator valve as that's what seems to be a little different. The main safety valve is the same as in the book. A photo of the flow divider would help make sure I have the right one.
Part of the problem with this one on the flow divider is that the bore is worn and I think the valve keeps sticking. I've taken and smoothed the valve and removed the sharp edges and that seems to be helping.
Email is Camarowin@gmail
Thanks
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
