Re: Farmall 706 fuel bowl slow to fill?
Posted by Patrick HMD on January 24, 2013 at 20:48:04 from (75.16.103.74):
In Reply to: Farmall 706 fuel bowl slow to fill? posted by John V. on January 24, 2013 at 17:32:06:
I can only think of two things that would be causing this problem.
1. Tank not properly vented. Have you tried turning on the gas with the cap off the tank? If it's still the same, then tank is properly vented.
2. Crud, loose rust, or other foreign matter maybe causing blockage at the outlet. How clean is the inside of your tank?
That's all that comes to mind. Good luck..
HTH
Patrick
'49M
