Re: Farmall 706 fuel bowl slow to fill?
Posted by Owen Aaland on January 25, 2013 at 02:42:43 from (216.47.34.216):
In Reply to: Farmall 706 fuel bowl slow to fill? posted by John V. on January 24, 2013 at 17:32:06:
One other thing will cause the sediment bowl to fill slowly. If the carburetor is full of fuel the needle valve will be closed and the there will be no fuel flow from the sediment bowl to the carburetor. In order to fill in that situation all the air in the sediment bowl has to pass up through the gasoline as it comes from the tank.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
