Re: loader plumbing
Posted by IH fan on January 25, 2013 at 05:13:45 from (108.238.226.213):
In Reply to: loader plumbing posted by carlsandberg on January 24, 2013 at 18:01:15:
carlsandberg said: (quoted from post at 21:01:15 01/24/13) 464IH Diesel with a loader, the loader is run off the rear hyd lines by the pto shaft, how would I plumb this to run the loader and have the use of the rear hyd fittings?
You will need a separate set of valves for the loader, and some means of dividing the flow (flow divider valve which will slow both systems down) or have a "pressure beyond" valve on the loader that feeds back to the tractor valves. If there is a tractor valve that allows "pressure beyond", that would work also, but I don't know if IH made allowances for that.
There is no way to split the flow off of the disconnects and use both without separate valves for the loader. You may be better off adding a pump and valves for the loader. The more stuff you try to run off one system, the more problems you will run into.
This post was edited by IH fan at 05:14:32 01/25/13.
