Re: alternator diode question
Posted by oldtanker on January 25, 2013 at 08:27:57 from (66.228.255.239):
In Reply to: alternator diode question posted by 55 50 Ron on January 23, 2013 at 17:35:15:
Ron, you need the diode or light bulb to keep the alternator from back feeding the ignition system as others have posted.
third party image
The picture shows how to just wire a GM alternator. That wiring will not change with a new harness.
Rick
