I'll give that a try. I'm pretty sure my SM has this problem. last time I check the oil is seemed to have gained some, not lost it. I just haven't gotten around to buy the tanker full of gear oil to replace it!
The only thing that turns when it's in neutral is the input shaft, right? I mean if a bearing went on it bad enough to make a knocking noise it's wouldn't just fix it's self...
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
