Re: Need info on 450 hydraulic regulator/safety valve block
Posted by rhtx55 on January 25, 2013 at 16:40:26 from (68.185.207.25):
In Reply to: Need info on 450 hydraulic regulator/safety valve block posted by Centex Farmall on January 24, 2013 at 18:29:15:
If the system is loosing prime, then I would be checking the metal lines that run from the pump up to the reservoir and their respective orings. The suction side is getting air in somehow or the reservoir pick up screen is plugged ( inside the reservoir) or dirty, or possibly the reservoir is low on fluid.
